![]() | Home > Technical > Timed climate |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
Ah. Never had to look at one with an internal module failure before...
jeffhunt Member Since: 19 Oct 2014 Location: Hayling Island Posts: 83 ![]() ![]() |
Might be clutching at straws, but have you connected the IIDTool again and checked that the dealers haven't reset the CCF so it is only showing FBH fitted & Park Heater not?
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Thanks jeffhunt, I checked with the IID Tool and all is still as I had set it. The timed heating screen still appears OK and I can set the timer, it just seems to work for only a few minutes. Driving me mad now. |
UPDATE and SUCCESS!
Minshy Member Since: 06 Jun 2014 Location: Mottram Posts: 48 ![]() |
Just had mine fitted last week.
Hi Minshy, I have been leaving mine set at about 21 degrees and on "auto." Battery needs to be OK and enough diesel.
Thanks for the response at least I have an idea what to expect next time I switch it on,
kljw Member Since: 01 Aug 2006 Location: Edinburgh Posts: 117 ![]() ![]() |
myfirsrtrrs
Keith,
Steve
Are you sure it's the aux heater? The position changed on the RRS2, tucked away left hand side at the back as you look at the engine bay from the front.
Hi
If it's fitted, it can be enabled |
dc44back Member Since: 29 May 2018 Location: London Posts: 151 ![]() ![]() |
How does it know what temperature to set at?
