Home > General > RRS MY11 Rear end lurches right on shallow road bumps
Purpology
2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
I've just bought a standard RRS MY11 Stormer Edition with the standard 20" stormer wheels on new pirelli tyres and every time I drive over a slightly recessed drain cover or shallow pothole (1-2 inches), the car seems to lurch to the right hand side. It's always when the rear left/nearside wheel goes over it, I'm always in standard driving height and it happens from 30mph+ and is very worrying for a few seconds after - feels a bit like the back end slips out by 10cm but DTC lights etc don't come on to tell me I've lost grip etc. Is this normal? Advice really welcome...
Post #451661 Sat Feb 07 2015 7:47am
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Thats weird. Never heard of this before. Could it be a poorly under inflated tyre? Daft question maybe but does it only happen on one drain or all drains? Nakered hub or wheel bearing?
I'd get my car on a ramp and put both hands on the wheel and give it a push / riggle and see what moves. I'm not Fat. RRS TDV6 HST.
Post #451664 Sat Feb 07 2015 8:53am
Purpology
Thank FatJoe - its on all drains, but forgot to mention its only on gentle road bends (left or right)...doesn't occur on straights...
Post #451665 Sat Feb 07 2015 9:01am
nigel52
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
My MY11 does exactly the same and I know all my tyres are fine. It is a weird sensation which I have just learnt to live with.
Post #451668 Sat Feb 07 2015 9:08am
Purpology
Thanks Nigel52 - thats re-assuring. As its still under warranty I took it into the garage today and they put it on the ramp and gave it a good looking and as well as taking it for a drive. Everything looks and drives as it should... Apparently its just me getting used to air suspension having just come from a M sport 3 series...
Post #451701 Sat Feb 07 2015 3:56pm
ACE 219
Sounds like a possible shock absorber (air bag) problem.
I expect the wheel is bouncing on the bumps which is causing the vehicle to lurch to one side.
I'm sure if this was normal every RRS would do this, but they don't. The shock absorber should soak up these small bumps & keep the vehicle driving in a straight line. You shouldn't lurch to one side when driving over bumps.
My guess is that the shock absorber isn't absorbing the bumps. RRS TDV6 Overfinch
Post #451705 Sat Feb 07 2015 4:52pm
Disco_Mikey
My money is on wheel alignment being out of spec Thumbs Up
As the suspension goes up and down, the toe angles also change. Hitting a bump in the road will extend/compress the suspension, exacerbating the alignment being out
Most places will check your alignment for free, or a small fee, which will put your mind at ease Thumbs Up
Post #451708 Sat Feb 07 2015 4:55pm
