Home > General > Newbie |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8968 |
The eyelet connector would be connected permanently to the battery. The waterproof connector block would then just sit in the engine bay. You could tuck it under the battery box cover or, for easier access, you could leave it just sticking out (behind the FBH for example). When you want to charge the battery you then just open the bonnet, connect to the waterproof plug and leave it. If you buy the extension lead then the Ctek unit can be positioned in the garage, for example, out of the weather and away from the light-fingered. The waterproof connectors actually come apart quite easily so even if you forgot and tried to drive away the connector would come apart. The extension cable is quite thin so can be easily run out of the engine bay with the bonnet safely locked down.
Thu Jan 29 2015 6:15pm |
Goreskin65 Member Since: 07 Jan 2015 Location: Portsmouth Posts: 32 |
Cheers for your help and advice |
Thu Jan 29 2015 6:23pm |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 |
Just about to order one of these (CTEK MXS 5.0 TEST & CHARGE) as I make a lot of short journeys. It was -5C this morning and it took quite a few turns for the beast to start - don't want to kill my battery...
Tue Feb 03 2015 9:27am |
I have one of these.... http://www.ebay.co.uk/itm/New-CTEK-Multi-M...046wt_1402
Tue Feb 03 2015 9:42am |
P1 as in McLaren P1?
Tue Feb 03 2015 10:20am |
That's what I've got Ady
Tue Feb 03 2015 10:21am |
Errrr no, as in Impreza P1. |
Tue Feb 03 2015 10:46am |
Ady - whoops - couldn't have guessed more wrongly if I tried! Still a nice car though
Tue Feb 03 2015 11:08am |
