Home > Technical > Question about access mode? How often? |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
I use access mode all the time - IMO it should not cause premature wear on the components 16MY Estoril Blue SVR.............
Sun Feb 01 2015 11:05am |
Hayden Member Since: 10 Nov 2013 Location: Isle of Wight Posts: 87 |
I always use access mode. just got used to pressing the button when parking,Think it looks a lot nicer. Think it may shorten the life of the compressor.. |
Sun Feb 01 2015 11:31am |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
Same here, I normally use it all the time, plus the beast LOOKS better when sitting lower down RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Sun Feb 01 2015 11:46am |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 |
I always use access mode when parking up for the night.
Sun Feb 01 2015 11:47am |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Never really bothered with it as it lowers itself anyway, as reguards to the compressor unsure on that one, plus the fact Ronnie Corbett is probably taller than me , Must say side steps help 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Feb 01 2015 11:54am |
Gornal how do you get the car to lower itself, would like to add that option to my rrs RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Sun Feb 01 2015 11:58am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
I never use access height - except for perhaps once a year when old folk need a lift. Off road height yes, access height no. 2012 SDV6 - it's missing a couple of cylinders
Sun Feb 01 2015 12:13pm |
To be honest I don't know, it does it itself when I lock it, but only when locked, if this makes sense 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Feb 01 2015 1:09pm |
Intersting, I thinks this is one to look into! RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Sun Feb 01 2015 2:14pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Ive got side steps so the normal height isnt a problem for me. I just was curious as to what others did and whether not using it would either help maintain parts or whether it actually was worse by not being used. I'm not Fat. RRS TDV6 HST. |
Sun Feb 01 2015 4:28pm |
Hi
Sun Feb 01 2015 5:51pm |
Third button to lower? I thought for that to work the haszards have to manually switched on? Which then defeats the point.
Sun Feb 01 2015 5:56pm |
hi
Sun Feb 01 2015 6:10pm |
I already have the FBH from Paul at Bas. Its great this time of year.
Sun Feb 01 2015 8:06pm |
