![]() | Home > Maintenance & Modifications > Java Black Aerosol Cans |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Best to hand it over and leave it to the paintshop experts for the best finish |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
Absolutely agree 👍 |
YOUR PRIDE AND JOY SHOULD DESERVE ONLY THE BEST |
If you want some proper paint (instead of the coloured water that Halfords sell ) go to your local paint factor and they will fill aerosols for you. A good paint factor can also provide other products needed such as hi-build primer, plastics primer, panel wipe and such things. It is perfectly possible to produce a good finish yourself but it takes a lot of time and patience.
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
The best tips are preparation and time and the end results should be fine. The only thing is drying time and hardening of the paint. Bodyshops bake so drying is simply done in 30mins
