Home > Technical > FBH remaining on |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Mine does the same. I thought it should have switched itself off once the engine was up to normal temperature. I'm in the shed, I'll be back in the real world in a minute. |
Mon Jan 19 2015 4:17pm |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
Hello Tony.
Mon Jan 19 2015 4:23pm |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Does anyone know how economical the FBH really is ?? wouldn't of thought it drank a lot !! 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Jan 19 2015 5:50pm |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 |
Economy has probably decreased due to the winter diesel. This can make a reasonable difference to your mpg. |
Mon Jan 19 2015 6:06pm |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Thanks very much for the replies, has answered my question and put my mind to rest. |
Mon Jan 19 2015 8:04pm |
Hi guys.
Mon Jan 19 2015 10:14pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Hi Ufffe
Tue Jan 20 2015 9:15am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
The FBH shouldn't run without the engine running unless you have the timed system or something like BAS's remote controller. I would expect the garage would be very unpleasant to walk in to if the FBH had been running for a while.
Tue Jan 20 2015 9:30am |
I see, as you said if the fbh had been running there would have been a rather unpleasant smell, but there was definitely something running, it could well have been the fan that you mentioned.
Tue Jan 20 2015 10:41am |
The fan is part of the FBH I think. 2012 SDV6 - it's missing a couple of cylinders
Tue Jan 20 2015 1:35pm |
