![]() | Home > Technical > flat battery how to get in car |
N/S/F door handle remove the small handle cover behind is the key hole which will unlock that door. 2008 G4 RRSport TDV8 current
dannyboy Member Since: 10 Nov 2013 Location: oxford Posts: 32 ![]() ![]() |
ahh i figured it would be somthing stupidly simple ,ill do it when i get back from work , |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Battery and alternator might be a good place to start, these cars are very temperamental to voltage.....cold weather might have pushed the battery over the edge!! |
its a brand new vatra battery |
I'm assuming the spec of the battery either meets or exceeds the original? Are you able to measure the voltage at the battery with the engine running? Maybe use some jump leads to start, if you have breakdown cover you could get them to come out and test....... |
Loose battery terminal, or earth point? ![]() |
nah it wont be that easy ,there must be a far more expensive issue |
Take the LR badge off, and replace it with another. Instantly halfs any bill |
JCHarris Member Since: 01 Jan 2015 Location: Solihull Posts: 18 ![]() ![]() ![]() |
Danny, what ended up being the problem? I have been having regular warnings about the battery and yesterday it came up with "charging system fault" with three warning lights. Took 6 attempts to start, but eventually did. This is the 3rd or 4th time this has happened now in as little as a week of owning the car ![]() My question is, do I lose my car to the dealer for them to hold on to it for a few days, or shall I just buy a new battery and hope the gremlins disappear? ![]() Just to add to the mystery, ran the webasto twice this morning and the car started first time without any faults. Seems intermittent faults will be the bain of my private life now, as well as my work. 2010 TDV8 Santorini Black. Side steps done. Remote parked heating done. Next up...Autobiography body kit. 2007 Disco 3 Java Black. Phantom Body Kit. Gone and not forgotten. Love Big Dog. |
it was the alternator and if its under warranty id deffo get it replaced as touch wood all my electrical issues seem to have |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
It dont seem too be your Battery,as your FBH will not start up if battery is low on charge If it would not start until six attemps it sounds like it could be a starter motor problem. Or iff it was turning over fast every time its probably fuel itisme |
Thanks for the advice. Ill keep my eye on it and the next time it pops up will take it back to the stealers. 2010 TDV8 Santorini Black. Side steps done. Remote parked heating done. Next up...Autobiography body kit. 2007 Disco 3 Java Black. Phantom Body Kit. Gone and not forgotten. Love Big Dog. |
