Home > Faults & Fixes > Wipers not wiping after squirting windscreen |
Are you pressing the squirt button for long enough? The wipers should make two passes after a squirt longer than 0.5 seconds.
Wed Jan 14 2015 1:48pm |
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 |
Problem solved
Wed Jan 14 2015 1:52pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
I find this feature quite useful as sometimes it takes a while for the pump to get the fluid out - and the blades have got half way across the screen causing smears. A few very short pushes of the button gets some fluid on the screen before the wipers move. 2012 SDV6 - it's missing a couple of cylinders
Wed Jan 14 2015 10:22pm |
