Home > Faults & Fixes > Wipers not wiping after squirting windscreen
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
As the title suggests, when I press the squirter, I get the water on the screen, but I have to manually turn wipers on. Every other car I have had the wipers automatically come on after the squirters have been used, even when wipers are in the off position.
Post #448417 Wed Jan 14 2015 11:07am
Paddi
Are you pressing the squirt button for long enough? The wipers should make two passes after a squirt longer than 0.5 seconds.
Can sometimes catch you out. 2008 MY Java Black TDV8 HSE
Post #448437 Wed Jan 14 2015 1:48pm
micalee
Problem solved Very Happy
I wasn't pressing it in long enough! Thanks Paddi
Post #448438 Wed Jan 14 2015 1:52pm
I find this feature quite useful as sometimes it takes a while for the pump to get the fluid out - and the blades have got half way across the screen causing smears. A few very short pushes of the button gets some fluid on the screen before the wipers move. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #448511 Wed Jan 14 2015 10:22pm
