Home > Maintenance & Modifications > 10 year with service B, ADVICE Please
kevtonge
United Kingdom 2005 Range Rover Sport TDV6 S Java Black
hi, my indy said if i get all the required oils filters etc, he do a service and the 10 year extras for labour £ 40 + vat per hour
so i will need?
brake fluid, how much and which 1?
fuel filter, which 1?
coolant, how much?
engine oil and filter, 7litre but which brand & filter?
transmission fluid and filter, how much?
axle fluid for front and back, how much needed?
have i missed anything? & what do I not need to do?
your help and advice greatly received
2.7 tdv6 2005, 70k, 100% road, under 6k miles a year 22" alloys
noob..... but better to ask than not Thumbs Up
Post #448002 Fri Jan 09 2015 9:49pm
BKHK
Why does he want you to get all the materials and parts? Why not just take it to an Indy who will do the whole job for you? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #448003 Fri Jan 09 2015 10:03pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Your indie should get all that stuff, they should look on auto data so they know all the right oil specifications. I've just had a big service and all 3 belts etc with my local guys. £700 all in for service, belts, pulleys. That was oil, filters, break fluid, coolant, pollen filter, fuel filter etc etc.even changed my front diff oil.
Post #448005 Fri Jan 09 2015 10:08pm
kevtonge
he will do the lot but he said if i can get it cheaper myself, then he will just charge the labour... hes trying to save me some cash..
Post #448006 Fri Jan 09 2015 10:10pm
FatJoe
If you save anything at all it'll be a couple of quid but if anything goes wrong with your parts etc it'll be down to you. I.e no warranty whereas if he does it and something go wrong pretty soon after then you'll have some come backs.
I've gone down this route with previous cars. Most of the time its a waste of time. Most garages will get the parts just as cheap. Mine does anyway, even cheaper than I can get on fleabay most of the time.
Post #448008 Fri Jan 09 2015 10:24pm
BKHK
I don't think it will save much by the time you have done all the running around to get parts and oils. A good LR Indy will have or be able to get it easily and will be all set up to do the job. I don't know why he thinks you will get the parts cheaper? The RRS is an enthusiast's car and one can't run and RRS always looking to save a few p (in my opinion) Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #448009 Fri Jan 09 2015 10:28pm
kevtonge
hmm, i never thought of it that way, thank you for the reasoning
Post #448067 Sat Jan 10 2015 7:45pm
