Home > General > SE v HSE |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8983 |
DSC is standard on all Sports as it's part of the overall ABS control system. It uses sensor inputs to determine if stability is being lost and can use changes to engine power and braking (including applying brakes) to control the vehicle. It's tied in to the Terrain Response system so that it has different stability parameters depending on the Terrain Response program being used. It can be turned off temporarily by the driver if required by use of a dashboard switch.
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Jan 02 2015 8:09pm |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 |
Thanks RRSTDV8 that's handy. Reckon I will look at the HSE over the SE |
Fri Jan 02 2015 8:59pm |
I've just realised you have a TDV8. That has both DSC and Dynamic Response. 2012 SDV6 - it's missing a couple of cylinders
Fri Jan 02 2015 10:18pm |
Thanks RRSTDV8. Tried the SE this morning & its not so tight on the turns so that explains what Dynamic Response does.. Also wasn't that impressed with the 3.0 litre engine against my TDV8 - felt laboured so will look over the coming months for a lowish mileage TDV8 (preferably facelift but they only did the V8 for a year max I think post facelift). Coming home I realised how good the V8 really is.... |
Sat Jan 03 2015 1:34pm |
