Home > General > Stealers, Ahhhhhhhhhhhhhhhh!!!!! |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Is this a main stealer? if it is you need to find an honest independent ? |
Tue Dec 16 2014 9:29am |
KJP Member Since: 13 Dec 2011 Location: St.Albans Posts: 9 |
Yes it is a "Main Dealer"
Tue Dec 16 2014 9:40am |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Always happened on mine - I leaned on it to make the connection ( tailgate close ) & then use the keyfob to lock & unlock - issue fixed
Tue Dec 16 2014 11:47am |
Just got it back and spent about 5 min's trying to get it to shut (or open) but no joy.
Tue Dec 16 2014 12:16pm |
Ok so the indy said that they could look at it but would advise that they too might have to damage the rear panel.
Tue Dec 16 2014 2:43pm |
told you 16MY Estoril Blue SVR.............
Tue Dec 16 2014 2:45pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Stealers are good at doing it the longest way round = most expensive. I only get a dealer to service the car to keep its history, learnt the hard way that anything else can be done better by myself. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Dec 16 2014 7:14pm |
mike21 Member Since: 07 Feb 2011 Location: Essex Posts: 297 |
All thinger's and fumbs no doubt 2019 BMW X3 2.0i M Sport in metalic black- Brilliant 2014 Mitsubishi Outlander PHEV Atlantic Grey, replaced with 2018 Frost White Outlander PHEV, can't fault em - now gone 2012 SDV6 HSE in Orkney Grey, Privacy Glass & Side Steps (notice a theme)! - Even better but now gone 2009 TDV6 HSE in Stornoway Grey, 20" alloys, Privacy Glass & Side Steps - Fantastic! but gone |
Tue Dec 16 2014 8:20pm |
JKay Member Since: 17 Nov 2010 Location: NSW Posts: 127 |
So what was the initial bill of £1,200 for if it didn't even address what you sent it in for in the first place? |
Tue Dec 16 2014 10:19pm |
New Battery @ £325, old battery was tested as been ok, they just advise it needed changing!!!!!
Tue Dec 16 2014 10:35pm |
Pads are easy enough to do yourself (see my link in my sig) and battery can be had cheaper than that, even for the LR gel battery (which is the best really). Bodsys Brake Bible
Tue Dec 16 2014 10:54pm |
TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96 |
Find an independent that uses LR or OEM parts.
Tue Dec 16 2014 11:07pm |
Ah stealers Huh. I got a new battery from Mercedes when I sent my E Class in and it cost 4 and a half times more than any other high end battery available anywhere else. When I queried them as to why it was so Expensive they said the current it releases is suitable for only MB vehicles. Needless to say I won't be getting any more batteries through my dealer .... |
Wed Dec 17 2014 1:10am |
