Home > General > Stealers, Ahhhhhhhhhhhhhhhh!!!!!
KJP
Right I'm absolutely hoping mad and it's a long story.
Car went to the dealers with a suspected alternator fault and they've come back with a list and bill of £1200 and that doesn't include the alternator!!!!!!!!
But the final straw was when they phoned this morning to say that the tailgate is still stuck half open half closed.
And they want to charge me the best part of £400 to break the interior panel so that they can replace the locking mechanism.
It was fine before it went in, I've told them that they can leave it as it is and I will attempt to fix it myself.
Anyone got any advise.
Post #445459 Tue Dec 16 2014 9:09am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Is this a main stealer? if it is you need to find an honest independent ?
Post #445461 Tue Dec 16 2014 9:29am
KJP
Yes it is a "Main Dealer"
I'm definetaly of to my usual Family Run MOT garage for any other work.
Post #445463 Tue Dec 16 2014 9:40am
PEACHY
Always happened on mine - I leaned on it to make the connection ( tailgate close ) & then use the keyfob to lock & unlock - issue fixed Whistle
Robbing Censored 16MY Estoril Blue SVR.............
Post #445477 Tue Dec 16 2014 11:47am
KJP
Just got it back and spent about 5 min's trying to get it to shut (or open) but no joy.
Found a Indy not too far away so going to pay them a visit shortly to see if they can help but not sure if they will be too interested.
Post #445487 Tue Dec 16 2014 12:16pm
KJP
Ok so the indy said that they could look at it but would advise that they too might have to damage the rear panel.
Anyway I've just spent 15 mins trying all the combinations mentioned in other posts and nothing happened, in the end it just took a bit of brut force i.e. I got annoyed and gave it a good kick with my size 12's.
It's now working fine, finger's crossed it stays like that.
Thanks for all you advise guys
Post #445511 Tue Dec 16 2014 2:43pm
PEACHY
Bow down Bow down Bow down told you Thumbs Up 16MY Estoril Blue SVR.............
Post #445512 Tue Dec 16 2014 2:45pm
simple1
Stealers are good at doing it the longest way round = most expensive. I only get a dealer to service the car to keep its history, learnt the hard way that anything else can be done better by myself. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #445561 Tue Dec 16 2014 7:14pm
mike21
2009 Range Rover Sport TDV6 HSE Stornoway Grey
It's now working fine, thinger's crossed it stays like that.
All thinger's and fumbs no doubt Rolling with laughter Rolling with laughter 2019 BMW X3 2.0i M Sport in metalic black- Brilliant
2014 Mitsubishi Outlander PHEV Atlantic Grey, replaced with 2018 Frost White Outlander PHEV, can't fault em - now gone
2012 SDV6 HSE in Orkney Grey, Privacy Glass & Side Steps (notice a theme)! - Even better but now gone
2009 TDV6 HSE in Stornoway Grey, 20" alloys, Privacy Glass & Side Steps - Fantastic! but gone
Post #445569 Tue Dec 16 2014 8:20pm
JKay
Australia
So what was the initial bill of £1,200 for if it didn't even address what you sent it in for in the first place?
Post #445587 Tue Dec 16 2014 10:19pm
KJP
New Battery @ £325, old battery was tested as been ok, they just advise it needed changing!!!!!
Front Brake pads low @ £316, This will be a DIY job once the warning light appears.
Anti roll bar bushes @ £209, didn't have to pay for this as it was only just 24 months since they were changed.
Rear tailgate @ £365 if they needed to replace the lock and panel.
All soon adds up, I didn't pay anything but will need to sort the battery and pads out at some stage.
Post #445589 Tue Dec 16 2014 10:35pm
Bodsy
Site Sponsor
Pads are easy enough to do yourself (see my link in my sig) and battery can be had cheaper than that, even for the LR gel battery (which is the best really). Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #445591 Tue Dec 16 2014 10:54pm
TheDB
Find an independent that uses LR or OEM parts.
LR AGP Battery, fitted, was £225ish
£316 for front brake pads is mind blowing. 1hr labour plus £70 in Brembo parts £150 would cover it.
Post #445593 Tue Dec 16 2014 11:07pm
JKay
Australia
Ah stealers Huh. I got a new battery from Mercedes when I sent my E Class in and it cost 4 and a half times more than any other high end battery available anywhere else. When I queried them as to why it was so
Expensive they said the current it releases is suitable for only MB vehicles.
Needless to say I won't be getting any more batteries through my dealer ....
Post #445599 Wed Dec 17 2014 1:10am
