Home > Technical > Rear wiper not working
ICMarshall
My rear wiper has suddenly stopped working on my MY2007 TDV8 HSE.
Washer works, but no wipe action. Nothing happens when I flick the column stalk to activate the wiper and nothing happens when I select reverse when front wipers are working.
Fuse appears intact but couldn't find my multimeter to check it out, but will do a swap test this evening.
Any ideas or suggestions of what to check before I take it back to the dealer
Post #445341 Mon Dec 15 2014 9:17am
rudadu
Scotland
If it's not electrical, the wiper motor might be gunged up.
I had a similar prob on my previous FL2. Rear wiper wouldn't move so removed it and dismantled to find it full of gunk. After removing said gunk and cleaning with paraffin and relube with grease all worked fine. I could hear the wiper motor trying to activate when switched on btw. 2016 L494 SDV6 HSE Dynamic Carpathian Grey
Post #445496 Tue Dec 16 2014 12:47pm
SilverAuto
Did you manage to find the fix for this issue as mine has just got the exact same problem. Motor is fine, as I've dismantled and checked it out and run it on an Independant power source.
Post #471306 Fri Aug 28 2015 7:18pm
R12345a
United Kingdom 2005 Range Rover Sport TDV6 SE Zermatt Silver
My rear wiper motor has gone (...i think). I've ordered a new one. Has anyone ever replaced this who can advise on how to swap step by step? Cheers
Post #477167 Tue Oct 20 2015 3:49pm
