Home > Technical > Lumpy Idle On Start-Up |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Had a look using the search facility, and a few of them point towards EGR valves or Air Flow Sensors, but ive blanked the AGR's and have a new sensor.
Thu Dec 04 2014 6:01pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Throttle body seal / Air flow meter seal, I only say this since I thought you had just had a replacement. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Thu Dec 04 2014 6:16pm |
Hmmmmm...... This doesnt sound like its going to be cheap...??
Thu Dec 04 2014 7:16pm |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
affraid not, they only really show fault codes when the electronics go bad or the smooth running evaluation maxes out.
Thu Dec 04 2014 7:49pm |
Darren
Thu Dec 04 2014 7:51pm |
Check temp sensors, including oil temp sensor.
Thu Dec 04 2014 8:00pm |
Cheers for the advice and the PM's....
Thu Dec 04 2014 9:04pm |
Darren
Fri Dec 05 2014 8:51am |
Car was fine yesterday, and it was a cold start.
Sat Dec 06 2014 8:50am |
