![]() | Home > Technical > Lumpy Idle On Start-Up |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Had a look using the search facility, and a few of them point towards EGR valves or Air Flow Sensors, but ive blanked the AGR's and have a new sensor.
Throttle body seal / Air flow meter seal, I only say this since I thought you had just had a replacement. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Hmmmmm...... This doesnt sound like its going to be cheap...??
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
affraid not, they only really show fault codes when the electronics go bad or the smooth running evaluation maxes out.
Darren
Check temp sensors, including oil temp sensor.
Cheers for the advice and the PM's....
Darren
Car was fine yesterday, and it was a cold start.
