![]() | Home > Technical > Rear door not locking |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Sounds like a door control module. |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
I had something similar on mine, but it was the drivers door. When I locked the car, the locking tab did not go all the way in, leaving the door unlocked. I had a new catch fitted and all is well. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Faulty door latch. Common problem on the RRS. 2014 L405 SDV8 RR Autobiography |
Before you get out of the car, press the locking tab on the rear passenger side door, then get out and lock the car as normal. Then try opening the door. I had to press the locking tab in on my drivers door when I got out to lock the car. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
martyn05, I tried that, locking it from inside the car but it does not unlock with the central (un)locking. It stays locked until I manually unlock it from inside the car. To be honest that is our temporary workaround to keep the car safe until we can get it fixed.
I do not know if it would be covered under warranty. I think it cost me about £100 to get it sorted. You would have to go through your warranty paperwork to see if door latch or door catch are covered. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Update to this: door catch mechanism replaced under warranty (Landrover Approved) by LR dealer. All working now. |
Result |
