Home > General > Ctek help please |
Can't help you with the wiring from direct experience but if you search the site including Disco 3 sister site there are some good guides. However can see that you'd have to remove the cover every time for access. For simplicity its hard to beat just using croc clips onto the battery terminals; or for a slightly more convenient connection you could use the 'comfort connector' accessory. The latter connects permanently to the batt terminals providing a weatherproof plug to use for connecting. 2008 MY Java Black TDV8 HSE
Sat Nov 29 2014 11:26am |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Can you clarify?
Sat Nov 29 2014 3:12pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
As far as I can work out, this charger works through the White socket or power supply to caravan socket and not tow electrics. Not sure how it works as most sockets are protected by a relay that only energises when it detects alternator is charging. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Nov 29 2014 5:40pm |
Yes, it works through the white socket(12s).
Sat Nov 29 2014 5:52pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5636 |
I have a ctek with 13 pin adapter and think it's excellent
Sat Nov 29 2014 9:25pm |
