Home > Maintenance & Modifications > Egr blanking question |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
The best is the two plates, as if they bring the EGR test in to the MOT test then they can't see that the car has been blanked just with the plates.
Sat Nov 22 2014 9:58am |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Yeah, as above.
Mon Nov 24 2014 8:56pm |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Do you blank it at the top where the pipes fit on to the air intake, also do you still remove the butterfly flap. Done a complete removal on my D3 but need to understand this one a little more |
Mon Nov 24 2014 9:02pm |
Back again but I need to ask this question, if blanked at the top with butterfly removed, does this or why does this show on the dash if the EGR are still in place and connected, is it simply because they can no longer operate correctly ?? |
Mon Nov 24 2014 9:09pm |
Guide is here:
Mon Nov 24 2014 9:11pm |
Thanks for that, i'll have a study |
Mon Nov 24 2014 9:13pm |
