![]() | Home > Technical > Low Battery Warning Message after having doors open |
If you are opening and shutting the doors but keep most of them open then i guess the lights will stay on because you are triggering the light switch. If you leave them all open then the system shuts down and all the lights will go off in around 10 minutes. When you say it had a good run, how far are you talking? If you have just bought it, how long has it been sat on a forecourt? These batteries take some charging from near flat. |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Since its a 2011 build vehicle battery is past its best. just had to replace mine in my 2011 build.
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 ![]() ![]() ![]() |
Me too |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
I had all these problems when cleaning my !0MY. Even if listening to radio when not running engine.I had a case when cleaning car,then not trying to starti till next day. And finding the battery compleatly flat. |
Remember Sport batteries need to be Absorbed glass mat, anything else could give you alternator issues |
I thought AGM was only a requirement for eco-stop/start equipped vehicles... 2012 SDV6 - it's missing a couple of cylinders
VARTA BLACK 90amp is the normal battery fitted by RRS. The Silver Dynamic is an AGM 100amp and handles the high demand that the RRS with extra electrical equipment,some have fitted,very well ![]() Varta do 3 grades of battery Black, Blue, and top of their range SilverThe Silver H3 i bought was £60 cheaper than quote for the black 90amp from main stealer itisme |
Tims Member Since: 20 Oct 2014 Location: Northants Posts: 11 ![]() ![]() ![]() |
The RRS has three major electronics systems which shut down sequentially. When you open a door you awaken the simple system and it will drain the battery over time to a point where you get that message.
