Home > Technical > Low Battery Warning Message after having doors open |
If you are opening and shutting the doors but keep most of them open then i guess the lights will stay on because you are triggering the light switch. If you leave them all open then the system shuts down and all the lights will go off in around 10 minutes. When you say it had a good run, how far are you talking? If you have just bought it, how long has it been sat on a forecourt? These batteries take some charging from near flat. |
Tue Nov 18 2014 9:16pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
Since its a 2011 build vehicle battery is past its best. just had to replace mine in my 2011 build.
Wed Nov 19 2014 8:36am |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 500 |
Me too |
Wed Nov 19 2014 8:52am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
I had all these problems when cleaning my !0MY. Even if listening to radio when not running engine.I had a case when cleaning car,then not trying to starti till next day. And finding the battery compleatly flat. I replaced it with a Varta 100 amp Silver H3. 5 year Warranty No problems since Purchased from Eurobatt Ltd Plymouth. £82.50 Free Next Day Delivery itisme |
Wed Nov 19 2014 9:58am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Remember Sport batteries need to be Absorbed glass mat, anything else could give you alternator issues In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Wed Nov 19 2014 1:08pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
I thought AGM was only a requirement for eco-stop/start equipped vehicles... 2012 SDV6 - it's missing a couple of cylinders
Wed Nov 19 2014 1:31pm |
VARTA BLACK 90amp is the normal battery fitted by RRS. The Silver Dynamic is an AGM 100amp and handles the high demand that the RRS with extra electrical equipment,some have fitted,very well Varta do 3 grades of battery Black, Blue, and top of their range SilverThe Silver H3 i bought was £60 cheaper than quote for the black 90amp from main stealer itisme |
Wed Nov 19 2014 2:05pm |
Tims Member Since: 20 Oct 2014 Location: Northants Posts: 11 |
The RRS has three major electronics systems which shut down sequentially. When you open a door you awaken the simple system and it will drain the battery over time to a point where you get that message.
Wed Nov 26 2014 9:28pm |
