Home > In Car Electronics > Downloading Phonebook
Page 1 of 3 123>
peterk
United Kingdom 2006 Range Rover Sport TDV6 HSE Siberian Silver
Hi guy's,
I am new to this forum so please be gentle......I have connected my phone to the car via blue tooth and it is all running fine.
My issue is the phone book has not downloaded so I don't know who is ringing, there was never an option to download it.
I had a freelander 2 but had no issues unless it is a car/phone mis-match.
The car is a 2006 2.7 HSE and the phone is a Samsung Galaxy 4.
Thanks in advance,
Pete
Post #442883 Tue Nov 18 2014 7:56am
Bodsy
Site Sponsor
sounds like you need to update the blutooth module. I can swap one by post to you.
Just need to check that it uses 2121 code to connect to your phone. if it does, then happy days. If it doesn't, then the only update is to rip the dealer fit module out and retrofit a new module (relatively easy to retrofit). Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #442894 Tue Nov 18 2014 10:37am
peterk
Cheers Bodsy, when I paired the phone I used the 2121 code and now every time enter the phone connects so I guess it's happy day's.
How do I remove the module as I want the updated one and whats the cost and address.
once again thanks.
Post #442895 Tue Nov 18 2014 10:46am
Bodsy
Site Sponsor
ill send you a pm with the info. Thumbs Up Bodsys Brake Bible
See it HERE
Post #442896 Tue Nov 18 2014 11:06am
Andyjay123
Ian, I have the same problem
IE names don't appear on my screen when someone dials in even though my phone book has uploaded
Help!!!!!!
Smile
Andy 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #442900 Tue Nov 18 2014 11:19am
Bodsy
Site Sponsor
There's no upgrade for yours Andy. You do have the phonebook to select from though don't you? Bodsys Brake Bible
See it HERE
Post #442906 Tue Nov 18 2014 11:28am
Cammy72
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Bodsy can you pm me details please , I connect with the 2121 and have no phonebook uploaded
thanks
Andy
Post #443223 Fri Nov 21 2014 2:05pm
garywmc
Scotland 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi Bodsy,
i'm looking to get the BT module update, can you help me out?
Post #461094 Sun May 03 2015 11:01pm
Bodsy
Site Sponsor
Hi gary,
Yes, I can do that. I'll drop you a PM. Thumbs Up Bodsys Brake Bible
See it HERE
Post #461098 Mon May 04 2015 5:59am
hutchy
England 2005 Range Rover Sport TDV6 HSE Java Black
Hi Bodsy,
I have a 2005 RRS and have connected my Iphone 6 via bluetooth and it works fine apart from downloading the phone book. Is there a software upgrade that can be applied to allow the phone book to be accessed.
Post #463768 Thu Jun 04 2015 1:57pm
Bodsy
Site Sponsor
There is, as long as you enter 2121 to connect. I have modules here ready to post out on a swap basis.
I'll drop you a PM in a bit. Thumbs Up Bodsys Brake Bible
See it HERE
Post #463770 Thu Jun 04 2015 2:21pm
Brianx5
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
same problem
Hi I have changed from Samsung 3 to Samsung 5 but I cannot transfer phonebook to RRS I use 2121 to register the phone but only picks up new phone number do I need upgrade to sort problem
Thanks
Post #463803 Thu Jun 04 2015 10:09pm
Bodsy
Site Sponsor
The updated module provides phone book capability Thumbs Up Bodsys Brake Bible
See it HERE
Post #463810 Fri Jun 05 2015 1:18am
TOELPEL
Spain 2005 Range Rover Sport TDV6 SE Buckingham Blue
Hi BODSY:
I sent you a pm but have not got an answer yet. Perhaps it was lost.
Here is my proposal to solve my problem:
I am not a mechanic but could talk in my dealer's mechanic to install your kit Disco 4 BT and the other hardware to modify the car. RRS 2005.
The dealer installed apart from the cables two modules. One as the basic phone module and another one which he calls the language module which is English.
The system works but is a pain even to store names with the phone number. Recognising my voice is probably one of the problems. But even numbers which are easy pronounced will not being read back correctly.
Which of the two modules will the disco 4 BT replace? Will it be possibly to give me written instructions on how to connect the items with perhaps a hand drawn plan?
If we can get those and instructions what to remove from the now installed system I will go into that adventure knowing that I could go back to you.
What would be the total price for your hardware?
Hope I am not too much a paine in the .... If you give me your phone number that probably would also help.
Post #465306 Sun Jun 21 2015 6:08pm
Showtime73
hi bodsy
i have just purchased my first rrs 4.2 and im looking to do my first mod.
currently using 2121 to connect to my iphone 6 and looking to get the phone book working,
i thing your the man to help
Post #466384 Fri Jul 03 2015 12:12am
Page 1 of 3 123>
