Home > Technical > Do you ever that 'clunk' when you put your foot down?
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
I don't drive my 2008 SC very hard but on certain occasions I have to plant my foot to over take on the highway...thats when I sometimes get this 'Clunk' from the drive train...almost like back lash in a coupling.
I have no vibrations or any other indications thats somethings about to let go...but it just don't feel right.
Thoughts? Ra-Ro Sport Super Dooper Charged.
Ford F350 Super Duty Prototype.
Ni$$@n Patrol 4.8 Overlander.
Post #442323 Wed Nov 12 2014 12:41pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Mine does this at low speed when coasting then when you put your foot down you get a "thud"
I tracked it to the prop shaft centre bearing, the rubber is weak and it moves quite a lot.
Post #442363 Wed Nov 12 2014 7:53pm
Alex C
2008 Range Rover Sport TDV8 HSE Java Black
LR did a gearbox software update on mine last time it was in and this solved that problem, 58 plate tdv8 not sure if the SC would suffer the same issue, might be worth asking them? TDV8 Java Black, Overfinch 22s
Post #442365 Wed Nov 12 2014 8:04pm
