Home > Technical > Do you ever that 'clunk' when you put your foot down? |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
Mine does this at low speed when coasting then when you put your foot down you get a "thud"
Wed Nov 12 2014 7:53pm |
Alex C Member Since: 09 Jun 2013 Location: Southampton Posts: 146 |
LR did a gearbox software update on mine last time it was in and this solved that problem, 58 plate tdv8 not sure if the SC would suffer the same issue, might be worth asking them? TDV8 Java Black, Overfinch 22s |
Wed Nov 12 2014 8:04pm |
