Home > Technical > Dead Key Fob
chi
Dead Key Fob
Hi All
My spare key failed several years ago. Have been using other key and now have finally changed the battery in
the spare. Still not working Embarassed
There was no power at all in the old battery so my question is has the circuit board lost its memeory because of no power for a year or so or am i best to get new key from landrover?
Many thanks
Keith
CHI
Post #442333 Wed Nov 12 2014 3:58pm
Paddi
I had the same problem - spare key supplied with the car had a flat battery but after changing the battery it still didn't work.
First get someone with a tester to see if the fob is transmitting a signal; if it is then have it coded to the car - takes a couple of minutes for someone with the right kit. Don't use a LR stealer though - they charge far too much. 2008 MY Java Black TDV8 HSE
Post #442343 Wed Nov 12 2014 5:05pm
chi
Hi Paddi
Thanks for your reply. Is there a way of easily checking if the key is transmitting before i go and try and have it re-Programmed?
Keith
CHI
Post #442924 Tue Nov 18 2014 3:35pm
Paddi
Not without a testing device. My indie keeps one on the reception desk - try ringing your nearest or maybe (if desperate) ask in Halfords if they have one Rolling with laughter 2008 MY Java Black TDV8 HSE
Post #442926 Tue Nov 18 2014 3:45pm
chi
OK Cheers Paddi
Post #442942 Tue Nov 18 2014 5:42pm
