![]() | Home > Technical > Another MPG post. |
Check tyre pressures
You can always add 250 ml of 2T next time you fill up, loads of info on here, plus the Disco & Freelander forum. Simple FB mineral oils will do.
When was it last serviced? An oil change and air filter change will probably give you another 1 mpg at least. If the brake light switch is faulty it may not be telling the engine ECU to cut the fuel when throttle pedal is released as it should do. Use premium diesel to help clean the engine. Having the fault codes read just in case there is something else wrong would be a good idea. Most importantly take it for a really good long run like about 300 miles and see what you get. If the previous owner used cheap fuel and just did the school run it takes a while to clean up the engine. Mine was similarly thirsty but now returning 27 mpg on run off mixed motorway and B roads. 2008 MY Java Black TDV8 HSE
Hi
cannon-fodder Member Since: 20 May 2014 Location: Kent Posts: 40 ![]() ![]() ![]() |
Hi James
JamesRoberts Member Since: 02 Oct 2014 Location: Hampshire Posts: 116 ![]() ![]() ![]() |
Tganks guys for all the advice,
Dan2020 Member Since: 24 Oct 2014 Location: Nottinghamshire Posts: 12 ![]() ![]() ![]() |
I'll follow this one closely, recently purchased a TDV6 and I don't think i'm getting what I should be. I do a 40 mile round commute mostly A roads with a little town driving and I returned 19.2 MPG on the last tank, this included a Hyperchips remap mid way through. |
Dan did you clean your MAF? As I said I got a slight increase after this. |
Also guys is anyone using additives? From what I can see it's a no no??? |
Not as of yet, I'll do it this week end and may change the brake light switch for the sake of it - see what this does.... |
Quick update, I haven't cleaned the MAF sensor or fitted the brake light switch yet |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Well I've had a few good runs of late. Mine seems to stick and I have to reset it 3 times but I'm back up to av 27. |
