Home > Maintenance & Modifications > Floor Mat Anchors
Sag
Floor Mat Anchors
Hi guys - just want to query something regarding anchoring the floor mats to the footwell.
When I got my 1st RRS, it had floor anchors fitted and when I bought some new mats, they slotted straight in and secured into place.
Now my new car hasn't got any and the mats are sliding around the place.
I have got the anchors, but there is no fixing point for them in the footwell.
My question is - Does the carpet need to be cut or drilled to attach these? Or do they just screw in?
I did a search and it has been bought up a few between 2006-2008 but no solid answer, so hopefully this will help someone else too!
Cheers :bow:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  LCFC. Receiver of threatening letters from Overfinch.
Post #441833 Fri Nov 07 2014 11:20am
MXSRR
England 2007 Range Rover Sport TDV8 HSE Sumatra Black
The anchors are normally supplied with the mats, and you screw them into the carpet Crying or Very sad MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's
Post #441838 Fri Nov 07 2014 11:55am
baxc
The anchors will just screw into the carpet, helps if you make a small hole first
Post #441845 Fri Nov 07 2014 1:28pm
SRE
Spain
My Car only has one location peg, not two. It's down to MY In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #441849 Fri Nov 07 2014 1:54pm
Sag
Thanks guys - I thought as much but wanted to double check there was no specific location under the carpet.
SRE - I think they changed to a single locator pin from MY08. LCFC. Receiver of threatening letters from Overfinch.
Post #441852 Fri Nov 07 2014 2:06pm
cubbyno9
Hi, could someone advise where to buy the anchor pins, is it only from LR or does anyone know any on fleebay, thanks in advance 2017 Range Rover Sport HSE
Post #443484 Mon Nov 24 2014 9:14am
