![]() | Home > Maintenance & Modifications > Floor Mat Anchors |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
The anchors are normally supplied with the mats, and you screw them into the carpet |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
The anchors will just screw into the carpet, helps if you make a small hole first |
My Car only has one location peg, not two. It's down to MY In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
Thanks guys - I thought as much but wanted to double check there was no specific location under the carpet.
cubbyno9 Member Since: 22 Oct 2010 Location: Stepps Posts: 149 ![]() ![]() ![]() |
Hi, could someone advise where to buy the anchor pins, is it only from LR or does anyone know any on fleebay, thanks in advance 2017 Range Rover Sport HSE |
