Home > General > checking/replacing boost hoses |
W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87 |
Bump, anyone?
Wed Nov 05 2014 4:12pm |
Might be better to start with the symptoms to help identify the issue.
Wed Nov 05 2014 11:07pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Apart from hoses, higher milage V6 have a habit of splitting bottom of intercooler. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Nov 05 2014 11:45pm |
cheers for the reply chaps
Thu Nov 06 2014 4:48pm |
Our Disco did this and felt like all but three horses had left the building while smoking on light to full throttle. Once detected using a smoke tester, all horse were stabled and no smoke.
Thu Nov 06 2014 5:49pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Mines split the intercooler at 69k- so not that high. Got the dealer to change the hoses to silicone ones when he had the intercooler out. They come in sets of 3, the smallest one was a to fit apparently but the two bigger ones are on. |
Thu Nov 06 2014 6:28pm |
cheers for replies everyone, other than a smoke test or pressure test how else can i check to see if the intercooler or pipes have split? i know a bloke who can do smoke tests but hes not exactly round the corner also it seems theres a fair bit of work in removing the intercooler so dont want to dive into it on a gamble. |
Thu Nov 06 2014 9:38pm |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
I was doing a coolant flush other week and checked on bottom end of intercooler pipe. The clip was loose and the end of the hose was full of grime and dirt. No split, just a loose connection. Car runs beautifully now, but could also be due to winter service and lots of tlc!
Thu Nov 06 2014 10:09pm |
hit the nail on the head there Bodsy Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Thu Nov 06 2014 10:16pm |
im getting white smoke, does this rule out intercooler or boost pipes? |
Thu Nov 06 2014 10:19pm |
Might be a good idea to explain the problem you've discovered. I'm no expert but I think it may help those that are in diagnosing the problem. I see lots of white smoke this time of year. You could also be losing coolant so check levels and leaks. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Thu Nov 06 2014 10:28pm |
also whine on throttle bit of a whoosh but only when letting off the throttle smoke is primarily white with a hint of grey in there |
Thu Nov 06 2014 10:30pm |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
Can you post a pick of this smoke? does it smell |
Thu Nov 06 2014 11:32pm |
ill try get one tomorrow
Thu Nov 06 2014 11:34pm |
