Home > General > checking/replacing boost hoses
W18ODY
cars developed a problem and i think it could be a hose thats blown off, ive had a quick look and cant "easily" see the hoses mainly the one that goes to the turbo.
is there much involved in getting to them? i know some people swap them out for silicone so im wondering if someone can point me in the direction of the easiest route.
my little 1.8t ibiza is a hell of a lot easier to work on than this haha
thanks in advance Thumbs Up
Post #441489 Tue Nov 04 2014 7:32pm
W18ODY
Bump, anyone?
hoping it is a hose thats the issue and i can get it sorted before it goes into the garage
Post #441582 Wed Nov 05 2014 5:12pm
Bodsy
Site Sponsor
Might be better to start with the symptoms to help identify the issue.
Common fault is the intercooler hose left hand front of the engine gets a split in it. Loads of black smoke usually and a whooshing sound. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #441645 Thu Nov 06 2014 12:07am
simple1
Apart from hoses, higher milage V6 have a habit of splitting bottom of intercooler. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #441648 Thu Nov 06 2014 12:45am
W18ODY
cheers for the reply chaps
i did post a thread a while back but couldnt determine what it was
symptoms are white/grey smoke and lots of it idle is ok but the tiniest bit of throttle results in a james bond style smoke screen
hadn't thought of the intercooler cheers for the heads up
Post #441746 Thu Nov 06 2014 5:48pm
simple1
Our Disco did this and felt like all but three horses had left the building while smoking on light to full throttle. Once detected using a smoke tester, all horse were stabled and no smoke.
Post #441748 Thu Nov 06 2014 6:49pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Mines split the intercooler at 69k- so not that high. Got the dealer to change the hoses to silicone ones when he had the intercooler out. They come in sets of 3, the smallest one was a Censored to fit apparently but the two bigger ones are on.
Post #441755 Thu Nov 06 2014 7:28pm
W18ODY
cheers for replies everyone, other than a smoke test or pressure test how else can i check to see if the intercooler or pipes have split? i know a bloke who can do smoke tests but hes not exactly round the corner also it seems theres a fair bit of work in removing the intercooler so dont want to dive into it on a gamble.
Post #441782 Thu Nov 06 2014 10:38pm
tanloverluke
I was doing a coolant flush other week and checked on bottom end of intercooler pipe. The clip was loose and the end of the hose was full of grime and dirt. No split, just a loose connection. Car runs beautifully now, but could also be due to winter service and lots of tlc!
Get on your back, under engine, offside by radiator, there is a plastic cover held in place by four plastic expansion pin thingys Embarassed. Open her up and have a look. I took the complete pipe out and gave her a clean. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #441788 Thu Nov 06 2014 11:09pm
tanloverluke
hit the nail on the head there Bodsy Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #441789 Thu Nov 06 2014 11:16pm
W18ODY
im getting white smoke, does this rule out intercooler or boost pipes?
Post #441791 Thu Nov 06 2014 11:19pm
tanloverluke
Might be a good idea to explain the problem you've discovered. I'm no expert but I think it may help those that are in diagnosing the problem. I see lots of white smoke this time of year. You could also be losing coolant so check levels and leaks. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #441792 Thu Nov 06 2014 11:28pm
W18ODY
also whine on throttle bit of a whoosh but only when letting off the throttle
smoke is primarily white with a hint of grey in there
Post #441793 Thu Nov 06 2014 11:30pm
Olly-ibiza
Can you post a pick of this smoke? does it smell
Post #441799 Fri Nov 07 2014 12:32am
W18ODY
ill try get one tomorrow
smells pretty rich
Post #441800 Fri Nov 07 2014 12:34am
