Home > General > Frozen Button?!
road2ruin
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
Frozen Button?!
I've gone down to the car this morning and I need to get some bits into the boot.....bad news is that I cannot press the boot button, it seems to be frozen stuck!! Has anyone ever had this happen?
Last night was the first cold night however I'd hardly consider it as cold enough to cause this level of problem. It does then concern me going forward that am I going to be stuck every time the temperature drops.
Post #441664 Thu Nov 06 2014 8:16am
Idea If you update your profile we might be able to help you with the problem by knowing which model of sport you have.
Post #441680 Thu Nov 06 2014 9:31am
MAW
Boot release programmed on your fob??
Post #441684 Thu Nov 06 2014 9:41am
MAW
Boot release on the dash work?
Split tailgate or one piece?
Post #441685 Thu Nov 06 2014 9:42am
jochem00
I have the same issue.
and don't try to push it in as it will remain pushed in and not come out
2007 RRS TDV8
Post #441692 Thu Nov 06 2014 10:56am
road2ruin
Apologies, I have a 2009 RRS TDV8
Post #441699 Thu Nov 06 2014 11:25am
road2ruin
Right, so I've just been back out to the car and it was definitely frozen this morning and I'm a little worried that this has happened on the first occasion of cold weather. I live in London so hardly get the real rural cold nights yet the boot was unusable this morning!
As far as I know there isn't a button on the dash to open the boot so I'll be stuck everytime the temp drops below freezing?!
Post #441704 Thu Nov 06 2014 12:00pm
Program you key fob to activate the boot Wink (instructions in the handbook and on here).
Also worth seeing if your switch is on the way out - plenty of threads on here about faulty boot releases.
If it's not the switch, I'd also treat the area to a generous helping of GT85 (better than WD-40 IMO) to repel water and stop it freezing in the future.
Hope that helps Smile ON THE WAY: BMW F21 M140i
Post #441709 Thu Nov 06 2014 12:54pm
road2ruin
Thanks for the response!
I had a look in my handbook and it says I can program to do the following:
• Panic alarm.
• Headlamp courtesy delay.
• Air suspension control.
No boot open.
I've had a search but can't find anything on here. Could you point me in the right direction?
Post #441715 Thu Nov 06 2014 1:28pm
road2ruin
Sorry, ignore me!
It appears that the online manual only had those options but the paper one in the car does have all of them!
Thanks for the help!
Post #441718 Thu Nov 06 2014 1:36pm
road2ruin
Okay, so I've been outside and I've reprogrammed the fob however it now opens the top glass rather than the entire tailgate. This is despite pushing the main boot button rather than the top bit of glass.
Any ideas why that is?!
Post #441721 Thu Nov 06 2014 1:47pm
MAW
Redo the programming I used to have that prob but second attempt used to solve.
I've had a 55 & 58 plate before current and cannot recall specs. Is there a lock and unlock button on the dash? Press both together for a couple of secs and boot opens IIRC
Let me know Thumbs Up
Post #441732 Thu Nov 06 2014 3:04pm
road2ruin
Cheers MAW, will give the dash buttons a press!
Post #441733 Thu Nov 06 2014 3:05pm
mark.b
2007 Range Rover Sport TDV8 HSE Stornoway Grey
Get some WD40 and sray around the outside of the button try and get the oil in as far as it will go that should help
Post #441790 Thu Nov 06 2014 10:18pm
road2ruin
Thanks for all the suggestions on this issue.
Despite playing around last night I just can't get the button to unlock the main boot however it does unlock the glass bit so it's a compromise and of more use than the panic alarm that was on there originally.
I have also been out with the WD40 to try and avoid the frozen button issue happening again. It's an odd one, it's the first car I've had that has ever suffered from this and I would haven't have said that Tuesday night/Wednesday morning was cold enough to have frozen it that solid!!
Extra thanks to MAW for your suggestion of pressing both lock/unlock buttons together on the dashboard, that works a treat so if, in the future, the WD40 fails me I'll now be able to get boot access.
Post #441817 Fri Nov 07 2014 9:39am
