Home > General > Leaving an RRS Sitting for 2 Weeks at a Time All Year Round |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
Not quite a 2 week regular roster but sometimes 3 weeks at a time, my RRS was fine. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Mon Nov 03 2014 10:37am |
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 |
Been on rotation for 17 years 2 weeks away every month & not had any issues with any RRS or Full Fat |
Mon Nov 03 2014 10:45am |
Just put your vehicle in access mode and it will be fine. |
Mon Nov 03 2014 10:54am |
JKay Member Since: 17 Nov 2010 Location: NSW Posts: 127 |
Excellent. Thanks Gents (or possibly ladies and gents) |
Mon Nov 03 2014 11:12am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
As Ady said - put it in access mode - I used to use SWMBOs FL1 during winter when I had the previous sport and never had a problem starting RRS after long periods sat in garage in access mode
Mon Nov 03 2014 11:28am |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
What's the benefit of leaving it in access mode, my I ask? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Mon Nov 03 2014 12:38pm |
The suspension is self levelling, for example, if your vehicle is left in normal height and it is windy or some of the air leaks out of the system, the vehicle will level the car up automatically, and this uses power from the battery to do so. So potentially, you could come back to a drained battery. Same as when you go on a ferry, its always best to put the vehicle in access mode. |
Mon Nov 03 2014 1:09pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
That's interesting to know & probably explains why I had no problems leaving my car in its garage for weeks on end as I had to use access height to get it in |
Mon Nov 03 2014 4:33pm |
TW3 Member Since: 18 Sep 2014 Location: Burgess Hill, West Sussex Posts: 27 |
Ady 55, If I leave my RRS parked at normal ride height for a couple of days it sinks to access mode hight. Is this normal, or do I have a problem? Thanks |
Thu Dec 18 2014 8:08pm |
wemeadows Member Since: 22 Jul 2013 Location: Washington State Posts: 21 |
My ole RR would drop to access height from normal height over the course of a day at work when it was in a covered garage.
Thu Dec 18 2014 8:45pm |
Wemeadows,
Thu Dec 18 2014 8:56pm |
ian-r Member Since: 21 Jul 2014 Location: Nottingham Posts: 49 |
yeh it will be fine |
Thu Dec 18 2014 10:05pm |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 |
The levelling cycle does not run continuously and should not run the battery down. It does its first check after 2 hrs, then runs a few cycles every 6 hours before ceasing (amount of cycles varies with software and model year). Clearly it can only adjust downwards.
Fri Dec 19 2014 3:39pm |
