Home > Technical > 2010 rrs dab antenna |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Think you'll find its in the boot drivers side behind the carpet. Other side of fuel filler cap. This is where the modules are located. Someone correct me if I'm wrong. |
Fri Oct 31 2014 10:34am |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 |
Thanks I had a look the module is there but not the antenna . |
Fri Oct 31 2014 8:49pm |
The antennas are in the rear quarter windows, you can just see the connection in the inside at the top. To get to these I'm guessing you may have to remove / lower the rear part of the headlining to access. |
Sat Nov 01 2014 6:51am |
Thanks will drop the head lining and have a look. |
Sun Nov 02 2014 7:06pm |
