Home > Technical > 2010 rrs dab antenna
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Can somebody help me on how to replace a dab antenna on a 2010 rrs I believe it's above the rear headlining thanks for your help.
Post #441003 Thu Oct 30 2014 11:55pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Think you'll find its in the boot drivers side behind the carpet. Other side of fuel filler cap. This is where the modules are located. Someone correct me if I'm wrong.
Post #441027 Fri Oct 31 2014 10:34am
merlin1
Antenna
Thanks I had a look the module is there but not the antenna .
Post #441071 Fri Oct 31 2014 8:49pm
ABSport
The antennas are in the rear quarter windows, you can just see the connection in the inside at the top. To get to these I'm guessing you may have to remove / lower the rear part of the headlining to access.
Post #441097 Sat Nov 01 2014 6:51am
merlin1
dab
Thanks will drop the head lining and have a look.
Post #441270 Sun Nov 02 2014 7:06pm
