![]() | Home > Technical > Transmission fluid amount... |
Did you top it up with the engine running? Otherwise you can't get enough in there. How much did you drain out? Doing it the way you have, it's recommended that you do a double flush, so change it again in a few miles. |
Did you use the correct sump and filter, or the BMW tin thing, there is near enough a litre (2 pints for old timers) more oil in the correct sump.
5.5 litres is around what comes out with a sump change.
curtx7 Member Since: 31 Jan 2014 Location: cumbria Posts: 3 ![]() ![]() ![]() |
I did top up with the engine running bodsy.
Torque converter, valve body, cooler and pipes etc.
My Car cost me a lot of my hard earned |
SRE I was told by I was buying the best replacement kit best filter very best oil and I did research what the best options and this did seem the best...
It is recommended to reset the adaptations of the transmission ECU after a gearbox oil change. You'll need a suitable diagnostics tool to carry out the reset routine so maybe a trip to a specialist is in order? Bear in mind that it is normal for the gearbox to behave a little oddly for a while after a reset until it adapts itself. Don't know if this would help your issue but worth a try? 2008 MY Java Black TDV8 HSE
