Home > Technical > Transmission fluid amount... |
Did you top it up with the engine running? Otherwise you can't get enough in there. How much did you drain out? Doing it the way you have, it's recommended that you do a double flush, so change it again in a few miles. Bodsys Brake Bible
Fri Oct 31 2014 9:47pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Did you use the correct sump and filter, or the BMW tin thing, there is near enough a litre (2 pints for old timers) more oil in the correct sump.
Sat Nov 01 2014 8:04am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
5.5 litres is around what comes out with a sump change.
Sat Nov 01 2014 10:10am |
curtx7 Member Since: 31 Jan 2014 Location: cumbria Posts: 3 |
I did top up with the engine running bodsy.
Sat Nov 01 2014 9:20pm |
Torque converter, valve body, cooler and pipes etc.
Sat Nov 01 2014 10:30pm |
My Car cost me a lot of my hard earned as my Sport is a Spanish car, it cost me a LOT more than a UK car so I do not see the point if penny pinching when it comes down to a simple thing like oil and filters. To my mind, fitting the correct parts let alone "mixing" different oils is cheaper than a new box.
Sun Nov 02 2014 9:58am |
SRE I was told by I was buying the best replacement kit best filter very best oil and I did research what the best options and this did seem the best...
Sun Nov 02 2014 10:36am |
It is recommended to reset the adaptations of the transmission ECU after a gearbox oil change. You'll need a suitable diagnostics tool to carry out the reset routine so maybe a trip to a specialist is in order? Bear in mind that it is normal for the gearbox to behave a little oddly for a while after a reset until it adapts itself. Don't know if this would help your issue but worth a try? 2008 MY Java Black TDV8 HSE
Sun Nov 02 2014 12:54pm |
