tanloverluke
I looked in to this also, and what I found that is if you use an OAT antifreeze that's the same color and "standard" as what's already in the car, then go for it. I've also read that any OAT antifreeze that's not the same color but is the same "standard" (in the case of LR it's wss-m97-b44-d) as what's already in the car is also fine. That's probably why the Halfords OAT antifreeze is marketed as "Compatible with all vehicle manufacturers' colours of OAT coolants." Apparently the colour is just a dye, used for identification and marketing purposes.
As for your car plan antifreeze, I can't see that it confirms to the wss-m97-b44-d Land Rover standard and I would not use it . Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Wed Oct 29 2014 9:55pm |
