Home > Maintenance & Modifications > transmission oil change overdue i think
Dan Stevens
Australia 2006 Range Rover Sport TDV6 SE Zermatt Silver
Decided to do a transmission oil change at the weekend Cool
Anybody think it may have been a little overdue Question Question Question Embarassed
Post #439960 Mon Oct 20 2014 3:04am
tanloverluke
brave guy. how much old oil did you get out Dan? I'd like this done soon and toying with the idea of doing it myself. Is it simple enough?
Thx / Luke Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #439966 Mon Oct 20 2014 7:52am
Dan Stevens
I actually didn,t drop the oil pan and filter. I drained it with the intentions of doing so but having seen how bad the oil was i just drained it and re-filled it with the intentions of doing it again this weekend.
I got nearly 3ltrs out just by draining it.
Its actually really easy:
remove the gaurd, undo the plug both on the bottom and side and leave to drain!
i then refitted the bottom plug and made a filler to put in new oil. (see pics) fill till it drains from the side plug and refit. With the engine running and your foot on the brake select all gears a few times and then turn off and recheck level by removing side fill plug. if it drains there is enough.
I'm leaving it a week then i'll do it again..... when i get red fluid back out i'll know it's all changed.
Even with just the 3ltrs i got out and replaced the difference is phenomenal
Post #440052 Mon Oct 20 2014 10:04pm
idrabble
Australia
My suggestion with anyone working on oil changes with the transmission system of any car is to always make sure you can remove the refill plug before you drain.
Never happened to me (I guess being an engineer makes you think about these things) but you definitely don't want to be stuck with not being able to refill.
Post #440057 Tue Oct 21 2014 12:01am
garrycol
Australia
Dan - looks like you have had the steel pan conversion - not so easy to do if you still have the original plastic sump.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #440058 Tue Oct 21 2014 12:09am
Dan Stevens
no it hasn't had the conversion.
i have the new steel sump and filter here to fit.
I was just trying to get to clean red oil before i went the full distance and ripped it all off.
Post #440059 Tue Oct 21 2014 1:02am
Dan Stevens
i too am an engineer by trade...... and i agree fully.
this also applies to diffs/engines/brakes etc. Always check where you fill something can be accessed before
you empty.
Post #440060 Tue Oct 21 2014 1:04am
garrycol
Australia
So you sucked out the oil through the filler hole (I didn't think the plastic sump had a drain).
Just interested as I have to do all this myself.
Where did you get your Lifeguard 6 from?
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #440062 Tue Oct 21 2014 1:53am
Dan Stevens
the drain plug on the plastic sump is near the cross member, undone with an 8mm (i think) hex head, refitted to a max of 8Nm.
My oil i got from a local independent Landrover specialist call MR Automotive.
Post #440063 Tue Oct 21 2014 2:00am
