Home > Maintenance & Modifications > transmission oil change overdue i think |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
brave guy. how much old oil did you get out Dan? I'd like this done soon and toying with the idea of doing it myself. Is it simple enough?
Mon Oct 20 2014 7:52am |
Dan Stevens Member Since: 19 Aug 2013 Location: Brisbane Posts: 47 |
I actually didn,t drop the oil pan and filter. I drained it with the intentions of doing so but having seen how bad the oil was i just drained it and re-filled it with the intentions of doing it again this weekend.
Mon Oct 20 2014 10:04pm |
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 |
My suggestion with anyone working on oil changes with the transmission system of any car is to always make sure you can remove the refill plug before you drain.
Tue Oct 21 2014 12:01am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
Dan - looks like you have had the steel pan conversion - not so easy to do if you still have the original plastic sump.
Tue Oct 21 2014 12:09am |
no it hasn't had the conversion.
Tue Oct 21 2014 1:02am |
i too am an engineer by trade...... and i agree fully. this also applies to diffs/engines/brakes etc. Always check where you fill something can be accessed before you empty. |
Tue Oct 21 2014 1:04am |
So you sucked out the oil through the filler hole (I didn't think the plastic sump had a drain). Just interested as I have to do all this myself. Where did you get your Lifeguard 6 from? Cheers Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Tue Oct 21 2014 1:53am |
the drain plug on the plastic sump is near the cross member, undone with an 8mm (i think) hex head, refitted to a max of 8Nm.
Tue Oct 21 2014 2:00am |
