![]() | Home > Technical > Terrain response |
I would say leave it in normal and change as required. If you can safely drive fast then the conditions don't require snow mode in my opinion. Grass/Gravel/Snow alters throttle response quite a bit IIRC. This may not be suitable at high speeds (if there isn't a limit that is). If you haven't driven in this mode, try it as you don't need snow to check out the changes it makes. You will then know what I mean. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
No, no max speed. |
