Home > Technical > Terrain response
Mark1505
Location: Wales Home, Singapore work & Also many other parts of the world,
Wales 2007 Range Rover Sport TDV8 HSE Java Black
Terrain response
Does anyone know if there is a max speed when the terrain response is in Grass/Gravel/Snow/Ice mode on a 2007 TDV8, I know when its in off road height at 30MPH it will drop back down, but don't know about this mode.
For winter driving in Europe I would like to have this setting switched on at normal hight but don't want to be stuck at 30MPH unless its deep snow. Also would leaving it in this mode cause any damage, or is it better to leave in normal mode and change as and when required.
Thanks in advance for your responses Java Black 2007 TDV8 HSE (my first RRS)
Colour coded door handles
Colour coded headlight washers
Smoked side repeaters
Hawk Colour coded side vents
Privacy Glass
Mud Flaps
Post #439797 Sat Oct 18 2014 10:20am
fkarim
I would say leave it in normal and change as required. If you can safely drive fast then the conditions don't require snow mode in my opinion. Grass/Gravel/Snow alters throttle response quite a bit IIRC. This may not be suitable at high speeds (if there isn't a limit that is). If you haven't driven in this mode, try it as you don't need snow to check out the changes it makes. You will then know what I mean. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #439804 Sat Oct 18 2014 12:48pm
Andi
No, no max speed.
Post #439811 Sat Oct 18 2014 1:40pm
