Home > General > Another day, another issue |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
Crikey! I will definitely be looking at extended warranty now!
Wed Oct 15 2014 9:13pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9010 |
I absolutely wouldn't consider running my RRS without a warranty - that's one thing that's worrying me as LR's warranty is not available once the vehicle exceeds 100k miles (mine's on 82k now and I'm going to be doing 2.5k / month for the next few months...at least until Christmas, anyway, maybe until April if the contract is extended. The warranty is due in August so next year might be the last year of LR warranty - if I'm lucky enough to get it that far before 100k comes up (which is obviously unlikely if I'm still doing this mileage in the new year)).
Wed Oct 15 2014 9:54pm |
If the DS was air sprung with a smooth V6 it would be a no brainer, the RRS on our roads just floats along! Mine tows just one horse, so probably wouldn't get close to the 2.5 ton limit anyways.
Wed Oct 15 2014 10:25pm |
peterg1965 Member Since: 20 Sep 2014 Location: Lancashire Posts: 81 |
RRSTDV8 - I hope you get your RRS sorted soonest, a bit worrying to hear of your problems, but on the brighter side LR assistance seem to be providing a decent service. Glad I will have the two year extended Approved LR warranty with the roadside assist, but hope I don't have to use it.
Thu Oct 16 2014 6:02am |
There's no guarantee that you'll get a LR according to the small print. Both times I've used Assist, however, I have had LR. FL2 this time and an Evoque previously. Enterprise offered me either the FL2 or a Landcruiser as both were at the dealership following other Assist calls out(!). I decided to take the FL2 for no other reason than familiarity having had them as loan cars when in for a service.
Thu Oct 16 2014 8:26am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Hopefully it won't require another turbo as mine did. The induction system should have been cleaned out during rebuild so no excuse for this and all previous parts and labour are covered by LR 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Oct 16 2014 9:53am |
PAS Member Since: 30 May 2014 Location: kent Posts: 70 |
hi all.I've had my V8 rrs now for about 4 months and it has started to whistle from 1500 to 2500 RPM's.In my work I go to lots of garages & I often ask about the turbo whistle on cars.some say its normal most turbo's do,don't worry about it.I've had an indy look at it & they said it's not that bad ,they wouldn't do anything.had it serviced at main dealer ,they say it's not that loud.I have got a warranty but I'm guessing they won't do anything till it goes bang.with all that's said on here I'm getting paranoid about driving it.it's a 58 plate with 56000 on it.any advice would be appreciated.I've replaced discs &pads all round.front upper &lower wishbones ,anti roll bar bush's &brackets.It had new rear bar under warranty as was leaking when I bought it , so I've spent a fair bit on her already.Like most people I love driving her .thanks for any replies.p |
Thu Oct 16 2014 8:04pm |
You shouldn't really hear the whistle normally. If it's pulling nicely when you press the throttle then you might just have a slightly noisy one - or your hearing is better than average. With mine, the whistle was accompanied by a noticeable lack of performance - although no warning lights / error messages on the dash. 2012 SDV6 - it's missing a couple of cylinders
Thu Oct 16 2014 8:30pm |
Just drive it and enjoy it. Let it warm up properly before putting your foot down, usually around 8 mile in mine, and after a run especially if the turbo has been put to good use, let it cool down, ie tick over for approx 2 minutes before switching the engine off.
Thu Oct 16 2014 8:32pm |
My L200 now has 120000 on the clock, has been used and abused and apart from routine maintainance has never required major surgery apart from a broken balance belt. It doesn't whistle, use oil and starts first turn of the key even when left parked for months.
Fri Oct 17 2014 7:21am |
I must admit, mine was abused from new right up to when i sold it with 45000 miles on it. Other than the turbo issue, it never missed a beat, but there has been quite a few that have thrown rods through the block. Has yours got the power upgrade Simon?
Fri Oct 17 2014 7:52am |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
What is a power upgrade please? I'm not sure that I would want this if it could possibly affect the ability of the engine to contain itself but I am curious. |
Fri Oct 17 2014 8:01am |
Box of tricks that boosts fuel and turbo boost. Takes a 155 bhp L200 to about 180.
Fri Oct 17 2014 8:12am |
Not unusual on this forum! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Oct 17 2014 8:23am |
