![]() | Home > General > RRS front wiper problem |
Have you had a screen replaced recently or battery changed? 2x TDV6. SE and HSE. Both returned to sender with issues👀
It has been known for the wiper arm to driving spindle connection to work loose - it happened to the O/S arm on my TDV8. Easy to check - make sure the wipers are in the 'park' position and pop the bonnet so you can access the bottom of the wiper arms, prise out the circular sealing grommet and check tightness of the nyloc nut underneath.
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
nothing has been changed, I can hear the motor going, and if I help the wipers move they do so with very little effort, but as soon as I let go of them they stop !
Perhaps a linkage problem then:
Cheers guys, I will get it looked at before buying bits I might not need, just got to find some one local as I cant drive for a month due to heart attack on sunday, so need to find some where close that wifey can find.
cootsie Member Since: 31 May 2014 Location: Turriff Posts: 15 ![]() ![]() |
Where about are Bob. I'm close to Turriff and there's a couple of places that would be able to help rather than a LR dealership. |
Thanks any way mate, but I live in Norwich, Englandshire.
Closer than Angola though... |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Blimey, I knew you had the odd issue with the RRS but a heart attack? Hope you get better soon Piggo, then back to Africa! Maybe buy something more reliable |
All sorted thanks guys, the drive had slipped on the motor shaft, easy fix, Glad I did not order a new motor at 160 quid. |
Excellent result |
