Home > Technical > Adaptive Xenon Problems
MM4747
Spain 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Does anyone know what causes the black oblongs that show up when high beam is selected on my 2011 MY.
Photos attached are the beams displayed on my garage wall.
many thanks RRS 2011 TDV6 HSE Limited Edition, Fuji. Previous owned: Vogue 3.5, Vogue 3.9, Vogue 4.0, Disco2, Disco3
Post #439290 Mon Oct 13 2014 6:27pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
I'm by no means an expert on subject, but I understand that dip / main beam is switched using a shade in the light unit, looks like it's not clearing properly on main beam!
Someone with tech info will be along soon.
Andrew 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #439310 Mon Oct 13 2014 7:49pm
MM4747
Thanks Andrew
Sounds like a good starting point. I’ll do a bit more research on the web but any more technical input would be very helpful.
On a recent visit to the UK I used the changeover levers in the headlight units to change from LHD lighting to RHD and back again. I wonder if I’ve done something when removing and replacing the headlight units, which I needed to do to make the changes?
Many Thanks, Martin RRS 2011 TDV6 HSE Limited Edition, Fuji. Previous owned: Vogue 3.5, Vogue 3.9, Vogue 4.0, Disco2, Disco3
Post #439354 Tue Oct 14 2014 9:35am
MM4747
Hi Andrew, removed the grill and headlight units.
Removed the round rubber cover to access the lamp area and there are two sets of levers. One set of plastic levers that hold the lamp in place and a thin metal lever that changes the direction from LHD to RHD.
When I first went in to change the lamp direction as per the handbook instructions I only saw the plastic lever.
Moved it back to its original location and then moved the metal one to its correct position. Problem solved!
Many thanks, Martin RRS 2011 TDV6 HSE Limited Edition, Fuji. Previous owned: Vogue 3.5, Vogue 3.9, Vogue 4.0, Disco2, Disco3
Post #439816 Sat Oct 18 2014 3:09pm
