![]() | Home > Technical > How do you turn the rear brake drum? |
If I remember correctly when carrying out adjustment of the rear parking brake you have to turn the rear hubs by putting a big socket on the hub nut. More details in Bodsy's brake bible which you will find on the forum. There is a correct torque for when you can just turn the hub. Hope that helps. 2008 MY Java Black TDV8 HSE
W33 RRS Member Since: 21 Aug 2010 Location: Carlisle Posts: 68 ![]() ![]() |
Yeah that's great thanks |
get both wheels on same axle in the air; will allow diff to rotate |
