Home > Technical > MY60 Spolier LED Brake Light - Removal/Replace
Cooperm28
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
As the header says, Ive had a few LED's fail on my spolier brake light.
As far as i can see there isnt any external screws/fittings to remove the light.
Does the whole spoiler need to be removed to replace the brake light?
If so does anyone have a link/how to, for removing as i can only seem to find 05-09 instructions online.
Thanks in advance.
Post #438691 Tue Oct 07 2014 5:40am
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
To remove the spoiler you have to first open the top half of the tailgate and unscrew the 2 screws holding the spoiler on ( 4 in total ) once removed close tailgate and open main tailgate and unscrew the other 2 remaining screws. The spoiler will just lift off but you will need to unplug the electrics and the water feed pipe to the washer jet. Once this is done the spoiler is fixed with a plastic underside trim. Remove this to expose brake light.
Post #438715 Tue Oct 07 2014 1:37pm
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
I found a video on youtube for this. It's very easy to do you just need torx bits to undo the bolts
Found it: http://youtu.be/uYh-dQYEimY Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #438785 Wed Oct 08 2014 2:42am
