![]() | Home > Technical > MY60 Spolier LED Brake Light - Removal/Replace |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
To remove the spoiler you have to first open the top half of the tailgate and unscrew the 2 screws holding the spoiler on ( 4 in total ) once removed close tailgate and open main tailgate and unscrew the other 2 remaining screws. The spoiler will just lift off but you will need to unplug the electrics and the water feed pipe to the washer jet. Once this is done the spoiler is fixed with a plastic underside trim. Remove this to expose brake light. |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 ![]() ![]() ![]() |
I found a video on youtube for this. It's very easy to do you just need torx bits to undo the bolts
