![]() | Home > General (L494) > 2 Questions (Brake Dust & Belt Chime) |
NTBeyond Member Since: 03 Nov 2010 Location: Darwin Posts: 28 ![]() ![]() ![]() |
The massive brakes on the RRS are brilliant but produce large amounts of dust.
KiwiCool Member Since: 25 Sep 2006 Location: Hanmer Springs, New Zealand Posts: 71 ![]() ![]() ![]() |
Hi NTBeyond
Try it with the engine running, been reported that this helped with D4 2014 models whereas the earlier versions needed only the ignition on. As for the door chimes, I'm afraid no way to turn that one off at the moment. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
This is supposed to be pretty much bullet proof and will keep the brake dust and maintenance down...
