Home > Maintenance & Modifications > How to remove lower glovebox 2005-09
Sag
Hi guys,
As per the title, looking for advice on how to remove the lower glovebox. I have pressed hard on the guide arm to release that and now it is only held in place with the locating pins/hinges at the bottom.
Does anyone know how to remove these and then re-fit my new glovebox?
Any help appreciated. Would like to add some pics and make this a how to if I can!
Cheers guys Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #437967 Sat Sep 27 2014 3:19pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi the lower glovebox is part of the top glove box it's one frame with 2 glove boxes you need to remove the heater vent and centre and then remove all the screws and the bottom side cover and pull it.
Post #437968 Sat Sep 27 2014 3:39pm
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
As above ^^
But be aware there is a screw on the right side, which can be a real pain to take out, sits kind
Of flush with the centre console trim, but apart from that its pretty easy.
Post #438004 Sat Sep 27 2014 10:16pm
Sag
Guys, I don't want to remove the framework. Just the cover.
As my pic shows, it hinges to the frame. My new glovebox cover needs to be fitted here, but I dont know how to remove the current one as there are, what seems like, spring loaded locator pins.
Any ideas?
Post #443172 Thu Nov 20 2014 8:55pm
