Home > Technical > Spongy rear brakes after caliper cleaning, advice please |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
So, I'm in the process of cleaning my rear calipers. Unfortunately I had to take the car out today, unplanned, so had to remount everything. It was my plan to wait until the new pads arrived.
Fri Sep 26 2014 2:00pm |
Thanks for that Ady! It does sound like I'm compressing air and that the sound is coming from the rear. I have some Castrol DOT 4 fluid so I'll perform the bleed tomorrow.
Fri Sep 26 2014 7:36pm |
Danny.H Member Since: 25 Aug 2014 Location: Brechin, Angus Posts: 91 |
I changed my rear pads the other week, I put a piece of clear plastic tube on the nipple, opened it up and got my boy to pump the peddle, once I could see a bubble free stream through the tubing and allowing sufficient time to pass the full pipework, I closed in the nipple whilst he was still pumping the peddle, I done both rears, never touched the fronts, topped up reservoir, nice tight feel to the pedal now, no spongeyness at all. I'm not saying you shouldn't do the fronts, I just felt the brakes were good with out having too. 2007 RRS 2.7 HSE - Java Black |
Fri Sep 26 2014 7:50pm |
Thanks Danny! Good point about doing rears only. I may anyway get a full drain and replacement at next service.
Fri Sep 26 2014 8:43pm |
You'll know when the peddle is on the down stroke with the flow, I just watched it and when the flow sped up i tightened the nipple. 2007 RRS 2.7 HSE - Java Black |
Fri Sep 26 2014 8:48pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
Why not buy a brake bleeder from your local car accessories shop. The one I am thinking of is called a one person brake bleeder and it has a weighted tube with a ball valve in the bottom to stop the system from drawing old fluid or air back into the system. They are very cheap and good to use when doing a full system flush. (LR recommends doing a full flush every 3 years)
Fri Sep 26 2014 10:51pm |
Barry, I'll be doing that on Monday!
Sat Sep 27 2014 6:05pm |
